Wiz-
Maybe I shouldn't offer advice (as I haven't hooked mine up yet), but have you tried blowing through the vacuum switch in both positions? This would be a simple test to see if your switch is at least toggling. You should be able to blow through it when your toggle switch is off, and then not be able to when the switch is on. If vacuum is "blocked" from the front axle prior to engaging 4WD LO, there is no way that the front axle can lock.
Also, you must flip the toggle switch first PRIOR to shifting into 4WD LO. Once the front axle is engaged, it might take a little bit of driving before it will disengage. I would be very careful about driving around with a floor jack under the rear.
David Dressler
2001 Driftwood 3500 Quad Cab 4x4, 155 inch WB, 5. 9L HO Cummins Diesel (ETH), 6-Speed HD Manual (DEE), SLT+, 3. 54 Anti-Spin Axle, Camper Special Group, Trailer Tow Group, Leather, Sliding Rear Window, Jacob's E-Brake, Rhino Liner, VDO Vision (pyro, boost, engine oil temp. ), Weather Guard Diamond Plate Saddle Box, Tork Lift camper tie-downs, AND functional Halo light!
Bigfoot 3000 10. 11 Slide-in Camper.
[This message has been edited by dresslered (edited 09-21-2000). ]
David Dressler
