mwilson
I am going to take time to share these pictures with you all, it seems that there have been several threads this week regarding malfunctioning CAD units.
Some want to repair the system, some want to replace it with a cable actuator.
The point I want to make with these pictures is whatever you plan on doing, do it before the wear begins. If you don't, the cable kit won't help you as the sliding clutch will simply snap the fork off or bend it.
If your light starts to blink when in 4WD get at it immediately or risk damages of at least $300. 00 just in parts.
These pictures are of the '97 that I bought last Dec. , it was January before I got it on the road and noticed the CAD problem. I fixed about 10 vacuum leaks and it still did it. I figured out what was going on and hoped it would make it until spring.
Well, it didn't. It got bad enough to break the CAD housing and fork one cold January morning so I had to deal with it right then.
One new inner RH axle, new shift collar and new CAD unit later it is as good as new.
See how the teeth on the inner axle have lost the blunt end and worn to a point???
There is no way that collar will stay on that shaft under pressure.
Notice the side by side comparison of the new shaft vs. the old shaft.
Thought you might want to see these.
Mike.
Mike.
