THANKS.
Towing 8,000# TT in Overdrive
US Gear Exhaust brake problem
Hi Guys: Thanks every body for answer my question. I'LL hope this sumer my truck and trailer run like 1999 truck and beside of any truck, because I was tire see every goes.
Hang in there Julio, you will get it running good! Then there won't be many passing you. I am a little surprised that you feel you are being passed by everyone though. Even when stock I usually passed the Fords going up a grade and then they would pass me again on the down hill side cause I would maintain my speed both in the up as well as in the down direction.
Have only towed once since the new injectors were installed and the one thing I noticed was how quick it was at takeoff. Also didn't pull down much on the hills. #ad
Stan
93 2WD extended cab, Banks Power Pack, K&N Air Filter, PW Injectors,Auto w/4. 10 rear with limited slip, US Gear Exhaust Brake, 31/2" Exhaust, 5K air bags, Boost/Pyro/Tach Gauges, Green/Silver, new 40-20-40 bucket seats, 149K
PacCool:
What injectors did you put in? I have the 300 hp ordered from BillK.
Preston
96 3500 Black 5 speed turbo diesel, SLT, with US Gear overdrive, Rhino liner, Reese 15,000 lb. fifth wheel hitch, US Gear de-celarator exhaust brake, muffler elimination kit, Amsoil lub. , with other goodys on the way.
I have the power wagons. They are off road injectors or so they say.
Stan
