Engine/Transmission (1998.5 - 2002) The EASY way to disable your HY wastegate!!!
Engine/Transmission (1998.5 - 2002) 24V is quiet
Engine/Transmission (1994 - 1998) Bhaf
I guess I'm missing something here. Here are a couple of scenarios:
1) completely disabling the wastegate and achieving 28-32 pounds maximum boost vs. modifying the wastegate to open at say 35-40 pounds and actually generating enough boost for it to open. Seems that the folks doing the latter are running the greater risk by pushing the turbo to run outside it's designed boost and RPM limits.
2) completely disabling the wastegate and achieving 28-32 pounds maximum boost vs. modifying the wastegate to open at say 35-40 pounds and only running a maximum of 28-32 pounds and never having the wastegate open. Seems like the folks doing the latter are in absolutely no better shape if their wastegate NEVER opens at max boost.
I understand the concept of a wastegate, but if you NEVER reach a boost level that will push the turbo to its designed limits or you purposefully set the wastegate to open at a boost level that you know you will never reach, what's the benefit of a working wastegate? Seems like there are lots of exhaust housings out there that don't have any wastegate at all. My 2 cents...
Steve
[This message has been edited by zman (edited 05-25-2001). ]
I remembering reading either on this board or in an email from Mark Chappel that th HY35 turbo becomes inefencent at boost levels of 32 psi or more. So if you try to go beyond that you are gaining nothing. I would say that once you go beyond the turbo's effective range you would begin to build more heat. IMHO... ... ... .....
2001 Flame Red Sport, Auto, 4. 10, 4x4, LOADED!, DC Sport Brush Gaurd, DC Painted Running Boards, DC Splash Gaurds, Line-x over the rails, BFG AT/KO 285-75r16
1998 Durango SLT+
2000 FL60, 16 ft. Flatbed, Cat Powered
zman, Good call but the reason for having the wastgate function "slightly higher"than that of which you can produce is So the Extra boost that you produce Can go somewhere when lets say you Yank your foot off the gas quickly when someone in front of you slams on the brakes... . That "overboost" from The exact moment the foot comes up, that pressure doesn't build up with no where to go and spin the impellor backwards. (Dredded Turbo "Bark")
Am I going in the right direction with this?
<hr>
<font color=#E02020><font size=3>Truck Bio:</font>
Y2K+1 <font color=#2F4F4F>3500 4X4 Quad Cab</font> L. S. D 4:10:1 Powerpacked (4 inch exhaust,High ram intake,wastgate mod to 38 psi,otto +guages,K&N) , Jakit's Front End Leveling Kit with 255/85R16 <A HREF="http://www.bfgoodrichtires.com/" TARGET=_blank><font color=#2F4F4F>BFG</font></A> <A HREF="http://www.bfgoodrichtires.com/catalog/radial_mud_terrain_ta.html" TARGET=_blank><font color=ff0000>M/T's</font></A> Custom Rhino Liner (see Tool Man's truck feature)DeeZee Goodies, Mopar Performance accessories-Sill plates-hitch cover-cargo aux lamp'n'Power, Hadley air systems 150 psi comp and air storage. Diesel Transmission Technology's ~93%TC~&~VB , TC Saver, Mag-Hytec'sDouble Deep Trans pan, DD1's + Van Aken Full Guages. Rubber side down & shiny side up can get a smile at the end of each day(hopefully)<A HREF="https://www.turbodieselregister.com/ubb//Forum17/HTML/001793.html" TARGET=_blank><font color=#E02020>See The Rig Here</A>
<A href="mailto:ToolManTimTaylor@aol.com"> #ad
</A> #ad
pictures
I've had a lot of people ask for the pictures that used to be linked to this thread, so I added them to my album:
turnbuckle pictures
I think this is still the easiest way to disable the hardlined wastegates found on the HY35 turbos.
Steve
Are we "deactivating" the wastegate with the turnbuckle or are we closing it? I recall the wastegate forces exhaust pressure to the turbine to spool up the intake air. At higher exhaust pressure the gate opens more to relieve the exhaust pressure. Correct? By holding the gate closed boost is increased but what about turbo and manifold temperatures? Hmmmmmmm????
George Eusterman
I am going to do this fix as soon as I find a cheap boost fooler,so I dont set off any over boost codes. I am trying very hard to hold onto a little thread of warranty.
