Gypsyman, I answered your other thread that Ken can do installs in Ogden. We are not doing any installs at this time in Vegas.
Mattymac - for a given power level, all the "supporting equipment" will be the same. This means that if your truck makes 450hp, regardless if it's done with a TST box or a rail pressure box and injectors, it will still need the same support equipment (gauges, exhaust, airbox, bigger turbo, fuel pusher kit, clutch or trans work).
That being the case, if you are truely looking to make the kind of power that requires all those other things, then the OPTION to do it in a way that doesn't kill turbo's is just that - the option. You can choose to do it another way, granted a little cheaper, but you will have problems with what is out there to support it.
We simply say that our turbo won't work with the TST box or VA box. We don't sell either, and don't feel that we should R&D them to offer stuff to make those boxes be reliable. If you want 450hp or 500hp, we can and have been selling products to do that for some time on the 3G trucks. If you choose to go another route, it's certainly your choice - but that choice forces other choices as well, the turbo being one of them.
We do have another turbo being built that should handle the TST and injectors pretty well, but it will be for the 500+hp range. It is not intended for 300-500hp trucks. It's a larger single, with good spool characteristics, very strong and dual ceramic ball bearings. It is on the horizon, but not here yet. The casting process takes quite some time.
Hope that helps.
