Engine/Transmission (1994 - 1998) Those with new camshafts
Short cut?
Don't know if that is the right way to describe it, but I saw a guy who posted on another forum and used wooden dowels in some sort of way to remove his cam and replace it.
He said it saved him from braking down the engine.
That is the "short cut" I was referring to.
That is standard procedure. Wooden dowels are used to pull the tappets up so the cam can be slid out from under them.
-Scott
Spool-up is faster and EGT is noticeably lower. Also picked up a mileage modest increase. No down side, all good.
Same results I saw.
Peak boost may be slightly lower, depending on fuel/turbo combo. The air flow is still the same, but less resistance from more duration means lower boost for the same flow.
I noticed on mine it spooled quicker to 20-25 psi, 25-30 was about the same as stock, and 30-33 was a little slower than stock.
Stock cam I hit 30psi at about 1950 rpms, now I hit it at about 1975-2000 rpms, but its a lot more air at 30 psi vs the stock cam.
-Scott
Exactly, its a kit sold by Cummins.
