A few questions for comment by folks that have done upgrades to 4th Gen trucks.
My truck looks level in stock form, do you not need a leveling kit with the 4th Gen trucks? ... I "needed" one on my 3rd Gen with bigger tires.
Is anyone running 285's or 315's on a 4th gen 2500? If "yes" I would welcome input on you whether the leveling kit is needed/desirable and some photos if you care to share. I am trying to make a decision one way or the other. It has been a while since I had my '03 with the 315's and my memory is hazy. Also regarding wheel flares, is the MOPAR flare that is on the Power Wagon and Laramie's sufficient with 285's or 315's or do you need a bigger/wider flare? My Big Horn did not come with flares and I like the look of the factory flare if it will give you the coverage you need for bigger tires.
Also what are folks impressions regarding the stock shocks? ... and what shock would be the best for an upgrade if it is worth the money to do so.
I don't expect to tow over 10K at present and if I do I will probably look at putting on air bags if I expect to regularly tow north of 10K. The write up on the Pac Brake bags with ping tanks in recent issues was a good read. What is the tow weight (generally) where you may want to consider air bags and does the addition of them give you any non-towing benefits other than load leveling when you carry heavy in the bed? Finally, will bags give you increased carrying or tow capacity or should you still stay within Dodge's tow limits for your VIN even with bags?
Thank you for your thoughts.
