So I took my '94 in to get a couple recalls taken care of (Throttle & hood latch) and as I'm getting to the dealer my truck does some funny or not so funny things. As I'm coasting to a stop the rpm's go up & down like I'm moving the accelerator a little bit. The only way I could stop it was to hit the pedal. Then the truck dies at a stop sign, so I start it back up (takes a few seconds to start). Drive of with limited power/hard to get it over 40 mph. So I posted before about this as it's happen a few times: http://turbodieselregister.com/forums/showthread.php?t=175309
So I figured I should get this throttle cable delt with first, maybe its the cause of part of this. So the Dealer calls me and says I need all this stuff because they can't keep it running. Here's the list: Liftpump $409, Fuel lines $265, Fuel heater ***'y $162, Fuel Filter $85, Valve cover gaskets/ adj valves $260, Adjust injection pump $135.
They said my fuel lines are leaking and my lift pump has a broken spring also the valves are loud. So I took it home (yeah I drove it about a half hour drive) and looked at it, noticed when I shut it off it was leaking. Well it was leaking from the banjo fitting on top of the fuel filter so I tighten that. I thought it was funny they said I need an $85 fuel filter, I just put a new one on maybe 70 miles ago!!
So if my lift pump is bad could I drive for half an hour?!! Can't I just fix the spring in it?
