Jetpilot said:
Be sure and O-ring your head plus install studs and try and keep drive pressure low, your HX 35 pushing 40# is going to create a lot of drive pressure. Drive pressure kills headgaskets... ... .
I'm not quite ready for that step. Waiting on funds for a 2nd turbo and will ring at the same time.
Jetpilot said:
The shop truck makes about 250 HP from nitrous
WAY too much for what I'm looking for. 50-100 hp is fine. Just a little kick in the pants.
The kit consist of:
Table 2 NOS Universal Wet Kit 02519NOS Parts List
Item Description Quantity NOS P/N
(1) 4AN Bottle Nut Adapter 1 16220NOS
(2) Bottle Nut Teflon Washer 1 16210NOS
(3) #10 N2O Bottle 1 14745-TPINOS
(4) #10 Bottle Bracket Set 1 14125NOS
(5) Fan Spray Nozzle 1 13500NOS
(6) Fan Spray Nozzle Adapter 1 13715-SNOS
(7) Fan Spray Nozzle Adapter Nut 1 13713-SNOS
(8) Nitrous Solenoid 1 16045NOS
(9) 1/4” NPT x 4AN N2O Filter 1 15560NOS
(10) 2 ft. 3AN Hose (Blue) 1 15060-1NOS
(11) Bottle Blow Down Tube 1 16160NOS
(12) Solenoid Mounting Bracket w/ screws 1 16500NOS
(13) Flare Jets 6 13760-30,-35,-40,-45,-51,-55NOS
(14) 18ft. 4AN Hose (Blue) 1 15302NOS
(15) Microswitch 1 15640NOS
(16) Arming Switch 1 15602NOS
(17) Wiring Relay—30 AMP 1 15618NOS
(18) Harness for Wiring Relay with 15 AMP Fuse 1 15604-SNOS
(19) 1/16” NPT Pipe Tap 1 15990NOS
A boost switch is also on my list along with a possible blanket.
