So are you coming to IRP to race?
KLockliear said:I'd say your first task should be to identify exactly how much power you are going for, and what you are going to use that power for. Twins will require the head studs and o-ringing mentioned above. For instance, a 2001 Dodge we used to have made 58xhp on #2, 740 with nitrous... single turbo, stock head gasket (in fact, the stock head had never been off) an stock head bolts. It can be done.
Sled Puller said:You should have built a Common rail, thats where the HP war is heading! :-laf
