Update for those wondering how to reseal the input housing on an NV5600.
Un bolt it and clean the surface carefully, try using a strong solvent on the bellhousing side since it's aluminum. You can use a scraper on the housing piece, it's a cast iron piece, but be mindful of the direction it was machined in, the marks in the housing are deep enough to catch if your're not careful and the anaerobic sealant used to seal the housing can only fill up too .015s of an inch according to Permatex.
Remove the oil guide, this is a press fit piece and re-use is not advised as it will take some force to remove. Carefully remove the input seal I use loctite 545 on seals at their matting surface but to each their own. Replace using a socket, install was easier than remove because of the seal's orientation.
Install the oil guide after the new input is pressed in, I use 545 on the sealing surface. If you don't have something able to fit the diameter of the oil guide to tap it in, carefully go around the perimeter making sure you hitting the outer most area that is supported by the seat below it. Next install you're shim or shims if you have one. I used the anaerobic sealant to hold it in place in the housing. Three small dots and spread them thin; the sealant is tacky and holds very well for assembly.
next do a final wipe down of your mating surfaces. For the sealant I used what came from the factory an anaerobic sealant rather than an rtv, I've been told you can use rtv but i'm not looking to give it a try. Anaerobic sealant is used for machined surfaces with very specific tolerances. I sourced my sealant from Torque King 4x4. As far as how to apply the sealant to the surface the whole face needs to be coated, a picture below will show an example. You can go ahead and apply the sealant, it will stay tacky and not set until there is an absence of oxygen. You want a nice even medium coat. Use you're finger to spread sealant from high spots to low spots.
There are 12 bolts holding this housing cover, and mine were gobbed with blue thread locker from the factory. I chose to get new bolts rather than clean these off because I didn't have the tools or the time, a trip to fastenal got me some beautiful new bolts matched to length with an oxide coating. I chose orange loctite for the thread locker, It advertises the strength of red with the removability of blue.
Install and guide the housing in place, and using two uncoated bolts at the northern and southern most edges of the housing install to hold it. Take note of them or mark them. Now begin installing the bolts with Loctite one by one. I recommend using hand tools for this instead of power tools, It's a cast aluminum housing no need to crack it. Get the bolts hand tight till you see the sealant pushing out the perimeter. After all the bolts are snug starting form the center and working you're way out in a diagonal criss crossing pattern torque the bolts to 20ft/lbs ( I sourced this from my 03 service manual). To compensate for the extension I was using on my torque wrench I gave them another 8th of a turn if that on the bolts.
You should get the sealant to squeeze out a good bit, which should mimic how it looked from the factory. The sealant will set in the absence of oxygen, and the excess pushed out will remain tacky.
With this your input seal housing should be installed, hope this helped someone. I struggled calling around to get an answer.
