Tire size differences for hauling
What happened to the site sponsers list
06 no-drill 5 wheel hitch
my bad, it is a 6-lug hub on torflex type axle. the problem has been finding a tire that stays under 30" with 3000lb capacity. the 225-75-15 is ~29. 5 according to several mfg specs. so far 215-85-16 or a 215-75-17. 5 are closest. good thing this came up or i may never have stopped looking for 5-lug wheels!
problem number two is that it is a company truck and it may take FOREVER for the motor vehicle folks to authorize a change. only took 2 trannies and 3 torque converters on the last F350 Power-joke to get them to come around... :rolleyes:
BEAST2B >>>>>> For heavy haulin' the 15" tires are not at their best. For 6 lug six hole 16" see etrailerparts.com for trailer wheels. Great bunch to deal with... ..... JIM
i want to know for those that changed to a G from a E tire. Did you change the rims as the E rims are not rated for the pressure of the G tires? :D
I don't want to steal the thread but at SouthwestWheel.com every wheel has a rating and the question still is does the dodge oem wheel rate for a G load ? :confused: :confused:
I have never been able to figure this out. I just got a brand newset of wheels and there is absolutely nothing stamped on them.
I have some wheels that have the size stamped on them along with "JJ". Some people have said that "JJ" means 80 psi but I do not think this is correct.
I quite sure that "JJ" has something to do with the tire profile or bead profile or something like that but not the load rating.
Jj
Example:... You'll notice it reads "6J x 14 H2 ET45". The "6J x 14" part of that is the size of the wheel rim - in this case it has a depth of 6 inches and a diameter of 14 inches (see the section directly below here on wheel sizes for a more in-depth explanation). The "J" symbolises the shape of the tyre bead profile. (More on that later)
Only has to do with the rim shape/conture...
