Tires Wearing out
Towing
rock chip prevention
I have a friend who has a '98 Ram He has had to replace the left front tire twice at only about 15000 miles each time. Apparently it wears on the outside somewhat unevenly. He has been told it is not an allignment or balancing problem. He was also told that it was a common problem with the Dodge Rams. I have 15000 miles on my '99 Ram and am not seeing the same problem. Has anyone else had a similar problem?
I have about 16,000 on my Michelin LTX M/S, they have been rotated once. They show no unusual wear and should last about 40,000 at present wear rate (no towing/heavy loads). I wouldn't call 15,000 miles of tire life normal, have inflation pressures been checked regularly and adjusted according to load? 50-60PSI is about right for the stock front tires depending on load, severe underinflation could wear off the outside edge very quickly.
99 QC SB 4x4
Is it a 4x4 or 4x2? My 4x4 has never shown any signs of uneven wear and is much better than my '88 Chevy 4x4 was. It needed frequent rotation.
Ron
'96 Club Cab 2500 4x4, 4:10LS, Auto, BD Pressure Loc, Mystery Switch,TST 230/605, Cummins Chrome, Mag-Hytec rear and trans covers, Boost, Pyro and trans gauges, Optima Red Tops, All black. Tow 14k HitchHiker triple glide 5th Whl. Also use 9. 5' Lance. NRA Life Member.
<font color=teal> The only tire wear my truck has is on the rear tires, if I could just get the rears to wear as well as the fronts I'd be in fat's city. </font>
Dee'sel
97 2500 Club 4X4 3. 54, Forrest Green/Edgewood, LSD 5 speed, K&N Air filter RE0880 & Psychotty, TST #11 all the way forward, #12 for winter, AFC spring kit, Geno's Exhaust Blanket, TST EGT gauge & TST 0-60 boost gauge in A Pillar, Hypo clutch ass. , Cat-be-gone, 4" Dynomax Bullet muffler, Crome 4" turn down, AmsOil GL-4 80W-90 in Trans , AmsOil 15W-40 Oil W/ Bypass system, AmsOil Ser 2000 75W-90 in front & Rear ends,
Lund WInter front, Leer Cab Level Shell, 235/85R16 Goodyears, Dyno'd 342 HP *NRA/USPSA member and proud of it*
Whoever told him it was not an alignment problem needs to go back to school. It's most definately an alignment or suspension wear problem.
2001 HO 6 speed Regular Cab SLT 4x4 3. 54 anti spin 2500. Used for the daily grind and sneaking away to some secret Baja beaches toting a cabover
I have 55,000 miles on my Michelin LTX tires now, and expect to get at least 10,000 more miles. I will definitely replace these with the exact same tire in the future. MEGA is a 3500 2WD and I put at least 70% of the miles on pulling our race trailer. Regardless of what your dealer has told you, you've got a mechanical problem causing the wear!
I only have 7000-miles on my truck and I was showing wear on the outside edges of my front tires. I commute over a winding mountain road everyday (a little on the fast side), so I can understand the wear. I'm just going to keep rotating them. I also have the Michelin's.
I have 144,000 miles on my Michelin LTX tires. I rotate every 6000 to 8000 miles and have never had to align the front end even after hitting a 14' alligator. I still have about 4/32's tread left. My tires have always worn evenly.
Something's got to be wrong to get such uneven wear.
1997 3500 club cab, 10' flatbed, auto, 3:54,dual Firestone air bags, 224,000 miles+
15k on mine and the only wear is from scuffing the rears on dry pavement #ad
PS: Have your buddy take it 2 a real line-up shop.
[This message has been edited by BV (edited 07-28-2000). ]
Dresslered. . Expect aprox 20k before replacement... The mountain roads and "slot car" driving style love to eat the tires. . #ad
... I got aprox 20k on my first set and I drive a few more miles of twisties than you... my second set I was over 60k before the wreck [they have another max 5/10 k left in them]... they are Mich. XPS lt235-85-16 a commercial grade of tire. I recommend this tire to any dually as they have a VERY HEAVY DUTY construction and DO NOT flex on the sidewalls !!! on normal road surfaces I would expect very high mileage if they can tripple the mountain wear . . another great application would be trailer/5er tires... well worth the $$. . they are available in m/s tread a big issue for me as snow area here... I special ordered them at Costco. . They take a few miles to "break in" and feel a little like walking on your toes during beak in. . great after that !!!
Gary
Thanks willy, I would be interested in trying the tires if they will still grip the road. No sense wrapping around a redwood tree to save a little tire wear. Also, will be pushing maximum GVWR with a slide-in camper.
David Dressler
2001 Driftwood 3500 Quad Cab 4x4, 155 inch WB, 5. 9L HO Cummins Diesel (ETH), 6-Speed HD Manual (DEE), SLT+, 3. 55 Anti-Spin Axle, Camper Special Group, Trailer Tow Group, Leather, Sliding Rear Window, Jacob's E-Brake, Rhino Liner, VDO Vision (pyro, boost, engine oil temp. ), Weather Guard Diamond Plate Saddle Box, AND functional Halo light!
"Diesel, it's not just for breakfast!"
[This message has been edited by dresslered (edited 07-28-2000). ]
ditto "have it professionally checked". I have a 98. 5 2wd with 40k and just put new tires on the front at about 36k. NO uneven wear, front or rear.
I haven't had any front or rear tires wearing out unevenly. I have had my front right tires start cupping, had aligned and rotated. First set lasted 67,000 still have second set on.
Missouri Mule 96 White 4X4 ST club cab,(grey int. ),5 spd, 3. 54 reg dif, 8 ft bed, 1 ft high cheater boards, front and side of bed,Pofile V bug shield,
99 Freight liner FL60 blue Cummins 24v 215 hp, 520 torgue,6 spd 3. 59 no spin rear, 16 ft dry box (white) 19. 5 low profile tires,Weight 11,000, gvw 23000, 11 to 12 mpg
Bill Thomas (Wild Bill)
Mike,there was a post here not too long ago where a Dodge tech layed out exact numbers for alinement,not just the ranges most shops use,perhaps you can find it in the archives.
