Today was not a good day...
Project 1tonfun
flywheel torque #
... but that may be okay because I got lucky last night. :)
Now today I had 2 problems with the truck... both probably related to lack of sleep ;)
1. Timing pin. I tried using it and sheared half the tip off. I can still feel part of it (maybe the entire half that sheared off) in the gear. I am thinking of what to do. Possibly try to "vacuum" it out? Or maybe remove the oil filler cap and try to push it out with an L shaped tool and catch it in a hose? Or forget about it because it won't cause any problems??? OR, try to vacuum or push it out but don't worry if I lose it because it won't cause any problems??
2. I was trying to find the top of cylinder travel so I used a 1/8" metal rod stuck in the injector hole. I didn't have a wooden dowel. Yesterday I didn't have any trouble at all. But today the end of the rod somehow got caught and the rod started to bend. I noticed when the engine was harder to turn and started to look why. If I look into the injector hole I can see a small mark or two in the top of the piston. Or maybe that's just where the carbon wore off. Any chance I bent something other than the thin metal rod??? I would think the parts are beefy enough that they didn't feel it.
The current position of the pump is right at/below the original index mark with the timing set at 1. 65 mm. I approximated TDC using the timing pin and the metal rod to check piston travel. Its possible the pin might be a little off. I tried to use a dial indicator to determine piston travel but my mount and rod extension weren't cooperating. I'll try again.
Thanks for your answers in advance.
First off quit tinkering with your truck, diggin up bone- doing things thats better left alone. Second, I hope too that all you did was knock some carbon off the piston. I'm not sure how a gouge in the piston bowl would affect performance/economy. If you did damage something bad, then this diggin up bone experiment just got expensive.
Not too sure about the timing pin/rubber tip. Actually I think I took mine off the other day as well. I'm not gonna worry about it, unless someone says otherwise. I just figured its rubber, and by me continuing to turn the engine over by hand many times, worked the tip to the bottom into the oil pan- hopefully. Of course I could've remove the pin and confirmed, but nah.
