DPelletier said:Hohn,
I understand what you're saying. I did say that I believe that the TAG is based on sound engineering principle. Regardless, I stand by my comment. If there was a SERIOUS design flaw in the turbo inlet pipe it wouldn't have been built that way. As you say, OEM's are always weighing the cost. Wouldn't cost Cummins much to have a different shaped turbo pipe, or to install a factory TAG, for that matter. To be clear: I believe (based on my experience) that the TAG concept is sound engineering principle, but I don't believe that you will see 4 mpg or an extra 25 hp using it!
Cummins has spent some serious dollars redesigning our engines lately in 2003 and 2004. 5. If a big advantage would be gained from a redesign of the turbo pipe, I have some faith that they would have done it.
Anyway, my original response was to the "Tornado Fuel Saver" and nothing has changed my mind in that regard.
As I said before, if I experience some of the full load/full boost turbo noises that others have reported, I'll order a TAG right away. But I won't expect to notice a significant change in fuel economy or performance.
Cheers
Dave
Car_nut57 said:Towing is where we have seen the best gains from using the TAG and everybody likes the quicker spool up. Thanks for posting your results. We are cutrrently testing a second version of the TAG for the 2003-2004 Cummins which moves the TAG about 1/4" farther away from the turbo. Moving this little distance increases turbo sound noticeably with performance virually the same or just slightly better than the current TAG.
Muleskinner said:This piece, along with the secret 200 MPG carburetor, are what makes crooks money. If you think about how it is supposed to work and how an intake system is designed, you will answer your own question. save your money.
If you remove the intake hose from a 600, you will find air directioning vanes in the elbow just in front of the turbo. Its not enough to condition the air like a TAG does, but Dodge must have felt it was worth doing.y-knot said:I say to you, Cummins seems to be pretty much up on things. If the TAG was so dang good, why isn't it installed at the Cummins factory? Or better yet, Let me know if you see one in the new 600.
Yes, its the TAG-III which is currently available although a little different than what we were experimenting with in Feb. 2004.barbwire said:Are you talking about the TAG 111, or are you working on a newer model than the TAG111?
Rman said:TTT you paint these pictures of doom and gloom, trucks burning to the ground, turbo's exploding with fierce fury. My gosh do you walk around looking for airplanes that are going to crash into yourself? You were probably exaggerating to prove a point, but i know someone who acts like that and it's a rather strange feeling to be around.
LMAO..... :-laf You ain't seen nothing yet.
