TPMS and valve stem recommendations for 19.5 setup
Blackstone Report
Torklift 2 inch front hitch ?
I think you'll find 100/101 is as high as they will read. At least that's the way it is on my truck. I run 104 to 108 psi. At least I'll know if the pressure drops below 100. I wonder if that's a parameter alphaobd can change?
Probably not. It is probably the range of the pressure transducer.
The OEM sensors are the same, aside from DRW inners, for 1500-5500. They should have no problems with LRG pressures.
Good point. For some reason I had thought they used LRF on 4500-5500 which would come under 100psi but checked and it is LRG so I was wrong.
