Track Bar Bushings
Snapped a bleeder
Tire pressure for 35/12.5R18
I have a 2008 QC 2500 4x4. Where can I get polyurethane bushing for the stock track bar.
Should I just change the track bar to one of the after market ones?
The truck is still under warranty
Thanks
__________________
2008 2500 QC, shortbed, Big Horn, Bluetec, 68RFE 4x4, 3. 73s, stock.
I thought that Genos had upgraded poly bushings.
If not, call Don Thuren at (805)886-9250 and he will have them, know where to get them, or he can sell you an excellent aftermarket track bar with poly bushings.
I just had one of his trackbars installed on my 2005, and the truck steers like new again, at least until something ELSE wears out... .
I bought mine from Genos as well a few weeks ago. The install was really easy considering it's sometimes a pain to get the old ones out. Mine took less than 30 minutes start to finish. I'd try this route first - the aftermarket bars are great but are many times the cost of the poly bushings:)
I used a ball joint press and chissle to get mine out... pressed the rubber out, then chisseled the outter sleeve out.
