I just got back from a 2300 mile trip as seen on another post, and 40 miles from home, I blew my right rear tire on my triple axle trailer... .
Now I don't know if I had a nail and it flattened and then blew from the heat or if it was heat or speed related... .
I checked the other 5 tires and the hot pressure was equal at 72# so I imagine it might be a leak then ripped off... . Not too much damage, there is some sheet metal behind it and the step folder for the rear door must have deflected it out... . so not too bad...
My question is, the tire says on the side, "mission" "max load"... ??? 225/75-15" D rate... Are these just a cheapie tire the manf. put on? are they speed rated to 75 or what?..... The rating per tire adds up to 15,500# which is the GVW of the trailer... I weighed the trailer one time, Loaded, and it was 12,000# on the tires..... So that is 2000# per tire give or take...
Another thing is the trailer is slightly nose up when hooked but less than a 1" on the leveler... . so the rear tire might be heavier by a few hundred if that... But given the weight they are carrying, I don't think it was a weight thing, I think I had a leak then it ripped...
Any thoughts on these tires? should I replace them as soon as poss with better ones? are there any "E" rate 15" tires? and are there any "special" trailer tires I should look at... I need something fairly durable since the trailer is a toyhauler and I go off-road over rocks and such... .
TIA for any help...
Eric
TIA for any help...
Eric
