JPS
Try here
www.southwestwheel.com
3,500 lb. Standard Spring Trailer Axle
Axle: 2 3/8" diameter x 3/16" nom. wall round tubing.
Brake: 10" x 2 1/4" electric is standard, a parking brake and a hydraulic brake are available as options.
Hub/Drum: Idler hubs and hub/drums available in 5-4. 5", 5-4. 75", 5-5", 5-5. 5", or 6-5. 5"
Lubrication: Grease
Spindle: Type 84 with an inner journal dimension of 1 3/8" and an outer journal dimension of 1 1/16"
Axles are available in different lengths or hub faces.
Axle price with idler hubs: $72. 64 each
Axle price with electric brakes: $186. 40 each
Axle price does not include springs, hangers, or u-bolts
Additional items for 3,500 lb. axles:
Leaf Spring Part Number: SW4B - $14. 63 each (need two per axle)
U-bolt Kit Part Number and Price: APUBR238BX - $11. 95 per kit (one axle)
Hanger Kit for Single Axle Part Number and Price: APS1BX - $15. 87
Hanger Kit for Tandem Setup Part Number and Price: APT3BX - $39. 51
5,200 lb. Standard Spring Trailer Axle
Axle: 3" diameter x 3/16" wall round tubing.
Brake: 12" x 2" electric is standard with a hydraulic brake available as an option.
Hub/Drum: Idler hubs and hub/drums available in 6-5. 5"
Lubrication: Grease
Spindle: Type 42 with an inner journal dimension of 1 3/4" and an outer journal dimension of 1 1/4"
Axle price with idler hubs: $128. 08 each
Axle price with electric brakes: $249. 05 each
My 28 ft Cougar fifth wheel has 3500 lb axles.
