Trans Band Adjust
Wind noise in cab
How long do the OEM shocks last
Does anyone know how many turns to back off the adjusting screws for the front and rear bands on a 2001 after tightening to 72 ft lbs.
My info only lists up to 98:confused:
According to DTT Front tighten to 72inlbs back out 2 turns ( Bill K prefers the 1/4" hex key method or so I assume as when he took mine apart he knew I used a torque wrench & felt I ahd it a bit tight) which I have come to the conclusion is about 2-1/4 turns out. The rear is turned out 2-1/2- 3 turns. ( The rear should not require adjustment very often, as it is only used when you manually put it into 1 or use reverse. )
