Cummins2014
Would you change 1/2 of your engine oil? Would you suck out the rear and front diffs if they are the type that can be fully drained?
All clean fluid and it's vERY easy to do. If you had a FORD it would have a plug on the converter and if you had a rebuilt trans the same. Would you leave the fluid in the converter if it had a drain plug?
No, no , and no. But I don't have a plug on my converter . Many on here are okay with the partial fill, I am okay with it. I asked you a question is there a benefit, if so, state it, if not, then what is your point .You say do a complete change, okay tell us why, when it seems the accepted method is partial. I have no problem sharing info, but I sure want to know why this complete fill is so important to you, and the benefit
