Engine/Transmission (1998.5 - 2002) transmission governor solenoid and pressure transducer
2nd Gen Non-Engine/Transmission Short in wiring
Does the governor mounting plate need to be removed when changing these things or is there a clamp of some kind that holds them in. Question arises as to the gasket underneith will be required before hand. ? Thanks for your help. :confused:
Depends on whether you want to remove the gov housing for cleaning. It can collect garbage in the passages so there is a benfit in removal. If the gasket has neve rbeen replaced I would have on on hand and replace it.
