transmission lines
Killer Dowl Pin--DC supporting defect?
TIE ROD END
I going to run transmission lines on the burb in the next couple of days and would like some opinions on what type of stuff to use. The factory stuff is way to expensive. 1/2" soft copper (L rated), rubber hose? No one seems to carry 1/2" steel.
Bruce
1972 Chevy Suburban with 1990 D350 4x4 CTD Chassis, 618a transmission, 12cm housing, tweaked pump, 3 1/2" straight pipe, autometer gauges
i just got though replaceing my transmission lines with regular hydrolic hose. . so far its working great! got it at carquest, 300 PSI stuff. been on about two weeks and just got back from a 700 mile trip and no probs.
1995, 2500, 4x4, 3. 54, auto,130,000 miles, custom fuel plate, boost and EGT gauges, 215 HP injectors, RE-0880, custom 4" from down pipe.
Smart man, I got caught in Southern Alabama last winter and had to have it done at a D/C dealership. Cost me a bundle!!
It cost me about $50 I think for the fittings and hose, and a couple of hours time... and I got rid of those silly plastic clip fittings #ad
and also I routed the lines up out of the way much better than factory... so I feel better about it... ... this was all after the hanger right on the oil pan wore a hole in the line and it started praying ATF all over the place #ad
but I cought it in time. . #ad
so... all of you with auto's... check the tubeing hangers and make sure they are not rubbing!!! ... Jim
