I am writing this for my Dad. I was driving his 2002 3500 2wd in Phoenix two days ago and after accelerating rather hard (3,000 rpm 2nd - 5th) form a rolling start I pushed in on the clutch and the engine died
and had to coast off the road. Dad put a FASS system in about three months ago and has about 2500 miles on it. Most of his use is towing his 5th wheel. So after we got it off the road ( he was with me. Not just out having fun in dad's truck :-laf ) I tried to restart it and all it would do is crank, but not even try to fire. when I would turn on the key the FASS system would come on and fuel pressure would come up to about 15 psi and then drop off a bit. We tried 8 or 10 times then Dad went for the starting fluid.
The engine was up to tempature so we we did not worry about the heater grid and the starting fluid doing bad things. After three tries the engine started and then ran fine for the rest of the day. And even now. This is the second time Dad said this has happened since he put the FASS system on. About Dad's truck. 2002 3500 2wd cummins 5 spd, PDR 35 turbo, 4" jardin exaust, Edge comp, SB con "ofe" clutch, DD2 injectors.
Any help in figuring this out would be great. Harlan JR.
