Hey guys, I didn't expect the batteries, they are only 3.5 years old, cranks pretty fast and voltage is good with the grids warming. Not suspecting loss of prime since it starts fine plugged in and sometimes hard starts after it has been driven a little while and only shut down for a few minutes. Yesterday, I didn't plug it in, unhooked the FASS relay and it still hard started but started faster. Ran it for a few miles. Sat for about 30 minutes and hard started again with FASS hooked up. Drove a few miles, stopped for a sandwich and when I came out it hard started again. Got home, sat in the drive off for about an hour and when I left, I unhooked the FASS relay again and it started good. I thought I was onto something but it started good the rest of the day with the FASS relay hooked up. Put the truck in the garage last night after sitting in the drive for about 5 hours, and it hard started with the relay unhooked. There goes that theory! Spoke to Doug with Bluechips diesel, he said if it is starting fine plugged in, it could be a solenoid or something else in the pump that is not reacting properly cold. This morning, truck was good and cold, put a heat gun to the VP44 for about 10-12 minutes, being careful not to melt the wire harness to the TPPS, cycled grid heaters twice, truck started good. I am cautiously optimistic that the problem has been located. Too bad it is the most expensive item on the repair list, but this is my 3rd VP and it has lasted more than twice as long as the other 2 combined so it has been on borrowed time for awhile. Was referred to Redline diesel a few weeks ago by Cummins Bridgeway, said one of their guys left to work there. Was hoping to find a local place, happy with the people at Action, but he didn't sound too positive about it being the ECM and when I called a couple of days ago, no one has returned my call. So, I will probably contact Redline on Monday, report my findings and see when they can take it to double check the diagnostics and install a pump if needed. $1500 pump and install didn't seem to bad, did on of the previous ones with help from a friend but don't have the time or desire to freeze my butt in the cold.
Thanks again for all the help, I will update until the truck is running good in hopes to help the next guy.
