TST PM3-Does it require you to pierce the wire?
This is the funniest "Vortec" generator ad yet!
Jacob Exhaust Brake??
I just got my TST PM3 and can't install it yet because they sent the wrong harness. I was reviewing the directions and am a little confused. Does it require the piercing of the inject. pump wire? Thx
Get the Grabber from TST
Don't use the Scotch locks that come with it. I had constant problems on my 2000 and eventually soldered it on. On my 2002, I bought a Grabber from TST and have not had any problems in 3 years.
Wiredawg
I have the TST Comp stacked with a Edge Comp, The 2002 requires a adapter harness as the Map plug is different than the 2001. I also soldered the wires for the pump feed.
Rick
I am using a Blue Chip pump cover.
I agree, I don't like things that pierc the wire. Allows corrosion to get started. Use a pump cover or solder that bad boy!
Dave
