One reason they can't declare any meaningful correlation between EGTs and various power settings and air mods is because there are too many variables. In other words, it takes quite a bit of experimentation for the recommendations to be accurate and mean anything substantive.
so I don't fault them for not indicating this. We all know that the stock truck runs hot and that any power mods require a pyrometer. So when you put this box on your truck and drive it the way you want, pulling the loads you have, at the speeds you need and at the required elevation, in various weather conditions and outside temps, and with whatever mods you have, you'll find out where your limits are. And the cool thing about this box is that the EGT protection allows you to make more use of the available power for short bursts on the higher power settings, while taking advantage of the "virtual lower power setting" accomplished by the de-fueling.
