TST Problem!!
ATS Commander,...how to
clutch problem
I just recieved back my powermax CR, for a reflash and plugged everything back in, even double checked to see if they snapped and went out for a test drive and the code 0336 came up and no power over stock :{ I was expecting smoke and power but not even anything on 9,9. Any idea? I may have to disconect it and send it back in again.
I had the same problem after reinstall, check and make sure that the cam and crank plugs are pluged in the right order longest one goes to the crank senser, Engine runs fine but no power from the box if Hooked up back wards
You'll also get a truck that runs fine but stock if you're not getting a reading from the MAP sensor.
-Scott
Check your connections make sure they are wright. When I installed mine I had mixed up some connections on the injector harness and it had the same symtoms that you are haveing
Well, that makes me feel like an idiot. I had the crank senor mixed up. thanks for the kick in the butt, Lightman. The new program runs a lot smoother than the old one. I haven't had enough time to mess around a lot with it, but so far I am impressed.
Ya I felt the same way glad I could help
