CBlack,
Turbo P/N in ReCon is 3802992RX. Price to a preferred customer would be app. $1075. 00 exchange.
Just wanted you to have some idea of reman price.
Here is a breakdown of your turbo... ...
Part numbers of components... illustration at bottom of this post... .
The parts lists don't come across too great so here is what you are seeing,
1st column is key number for illustration
2nd column is part number
3rd column is available Y or N
4th column *Ignore It*
5th column is description
6th column is quantity required.
Ref No Part Number For-Sale Shopping Cart Part Name Required Remarks
PP97114-01 NO Turbocharger
3802841 YES ADD Kit, Turbocharger 1
3538414 YES ADD Turbocharger 1
1 3037236 YES ADD Seal, O Ring 1
2 3519807 YES ADD Gasket, Turbocharger 1 Cummins Equiv. 3914388
3 3501188 YES ADD Plate, Clamping 2
4 3503100 YES ADD Bearing, Turbocharger 2
5 3503562 YES ADD Nut, Lock 1 M7 X 1. 00
6 3519163 YES ADD Screw, Drive 2
7 3519302 YES ADD Shield, Turbocharger Heat 1
8 3519336 YES ADD Shaft & Wheel 1
9 3527566 YES ADD Ring, Retaining 1
10 3527619 NO Dataplate 1
11 3528104 YES ADD Baffle, Oil 1
12 3528121 YES ADD Coupling, Elbow Hose 1
13 3528177 NO End, Adjusting Link 1
14 3528204 YES ADD Nut, Regular Hexagon 2 1/4 - 28 UNF
15 3528221 YES ADD Ring, Retaining 1
16 3528414 YES ADD Nut, Regular Hexagon Jam 1 5/16-24 Thd
17 3528933 YES ADD Seal, O Ring 1 M8 X 1. 25 X 20
18 3530556 YES ADD Screw, Hexagon Head Set 5 M8 X 1. 25 X 20
19 3530923 YES ADD Plate, Oil Seal 1
20 3530924 YES ADD Slinger, Oil 1
21 3531238 YES ADD Ring, Retaining 1
22 3532215 YES ADD Bearing, Tur Thrust 1
23 3532217 YES ADD Collar, Thrust 1
24 3532427 NO Baffle, Turbocharger Noise 1 Purchase Higher Level Assy
3575743 YES ADD Kit, Pre-Set Actuator 1
25 3532622 NO Actuator, Turbocharger 1
26 3522597 YES ADD Pin, Roll 1
27 3532631 NO Housing, Tur Bearing 1
28 3504967 YES ADD Washer, Plain 3
29 3532195 YES ADD Spacer, Mounting 3
30 3532196 YES ADD Spacer, Mounting 2
31 3532298 YES ADD Screw, Hexagon Head Set 2 M8 x 1. 25 x 55
32 3532600 YES ADD Bracket, Actuator 1
33 3532940 YES ADD Screw, Hexagon Head Set 1 M8 x 1. 25 x 35
34 3527759 YES ADD Connection, Adapter 1
35 3533163 YES ADD Ring, Retaining 1
36 3535001 YES ADD Gasket, Turbocharger 1
37 3535215 YES ADD Clamp, Hose 2
38 3536158 NO Housing, Compressor 1
39 3537167 YES ADD Impeller, Tur Compressor 1
40 3538468 YES ADD Hose, Plain 1
41 3756754 YES ADD Seal, Split Ring 1
42 3758848 YES ADD Seal, Split Ring 1
43 3759917 YES ADD Screw, Hexagon Head Set 4 M8 X 1. 25 X 12
44 3762259 YES ADD Ring, Retaining 4
46 3534812 NO Housing, Turbine 1
45 3709861 YES ADD Gasket, Turbocharger 1 Cummins Equiv. 3901356
