Engine/Transmission (1998.5 - 2002) turbo advice
okay the past turbo was a HTT 62/68/14
current turbo is a super b special 64/71/14 I like this turbo with the cam and redoing the timing and everything else I have the lag is not to bad but not the same as the HTT. A buddy of mine has a II ps 62/68/14 that he wanted to swap
I'm reading diff things on the II compared to the HTT would like to know what your opionions are on the IIps 62 I know if I went that route of twins it would be easy to do and alot more usable with daily driving. but with the super b special the only complaint is some lag. and not really functional for me to use for twins I dont know if my drive pressure with the super b special is better or if the II ps will be better.
mind u I do not have to swap just a offer.
2002 HO 6-SPD LB 4X4 QC BD 64/71/14 SB-DD3600 TST PM3/SMARTY MACH 4'S, RINGS/STUDS, BIG STICK,SPRINGS,HTT 3 PIECE,AFE/2 " 5" EXH GAUGES, FASS 150,DRAW-STRAW, DSS-BOX DT PRO-FAB TRAC BAR, CONV-T STEERING,BORGENSON BOX AND SHAFT,DUNKS TRACTION BARS, AIR BAGS,37" TOYO MT'S 6" RCD LONG ARM LIFT... THANKS RIP www.sourceautomotive.biz
