in my lotus elan I have a vacuum operated pop off valve and that is obligatory for a throttle equipped engine in order to prevent turbocharger damage. since on a diesel power is not determined by airflow but mainly by the amount of fuel and there is no throttle in the intake system the airflow is not restricted which means that there is non or little pressure on the turbo shaft. I wonder how it should harm the shaft and how a pop off valve should be operated on a diesel engine. please explain.
95 2wd, tst"4, 16cm turbo, 191 dv, 370 marine injectors, automatic with shift kit, edge racing workhorse billet conv. , 4" exhaust, k&N filter, gear vendor, 354:1, 20" wheels with 275/50/20
74 Aston Martin V8,
68 Scout I with 406 GM, Bow tie heads, flowmaster 3", MSD, holley super competition headers, 812 Holley carb, 1/8 mile 8. 61,
63 Scout with BMW Turbodiesel 6 cyl. engine, 5 speed transmission, Mercedes Benz front end with 4 piston caliper disk brakes
74 Aston Martin V8,
