AK RAM,
The point of the story is that when you have airflow, you can add fuel to it and make power. Airflow is more than just boost, it is also about density. I don't see what I have to be embarrassed about. 500 HP/1000 lb-ft is not all that extreme. The Sidewinder Dakota made 735 HP/1300 lb-ft, with a similar turbo. That engine was ice-water intercooled and had a better cylinder head which helps account for the extra 235 HP. Gale said on the show that the added air density from the airflow parts allows for a 30-40% increase in power AT THE SAME EGT. That is the message. Anybody can make power, but if you want reliable power without tearing things up, you MUST have air density.
You may have gathered from what you saw that “at 500hp and 1000tq just a new converter is all the trans needs to live a happy life” but that was not the point. You have to admit that the torque converter is definitely the starting point. Incidentally we have not been able to slip that converter yet at those power levels.
I understand that what you saw was “hype” because you along with others on this site will always take a negative perspective on Banks, and that's OK, you are entitled to your opinions. But the information that was presented on the show, specifically the need for airflow to properly make power, is a legitimate message.
Peter Treydte
Banks Power
