RyanB said:This is a little off topic but I thought I would ask on this post. I purchased a HTB2/64 from High Tech Turbo a few months back for my GMC conversion. I went with it because it the class I was aiming at to pull with it I had to run a single charger. I have since lengthed the truck (reg-cab into a crew-cab) and weight wise I will be over the 7500Lbs now so I am thinking about going all out or as all out as I can horsepower wise, so I am thinking about twins.
My question is does anyone know if I could possibly run my HTB2/64 for the smaller charger? The exaust side of the turbo is a 12. From what I have been hearing from pretty well everyone is that this turbo flows better and spools faster than a HX40 and is very close to HX35. If I were to put it with a 3B do you think it would work or no?
Thanks in advance... Ryan
J. R. Adkins said:Ryan I can help you out. IT will work well in a twin setup. I could even build you a set if ya want!E-mail me.
J. R.
Jim Fulmer said:Most people like the 23 but end up going to a 26 for a little better topend, you have a 35 on top so the bottom end should be fine, I've run the 26 but never the 23 and I never would... ... ... just an opinon!
Jim
I have the exact same setup. They do work very well with my DD (Extrude Hone) Stage 3's. I too see 60 PSI on a regular basis.Partyat33 said:I am running a 22 cm. Seems to work great. I have never ran another set of twins so I can not compare. Very fast spool, easily makes 60 psi and cut my EGT's about 300 degrees.
Dennis
I'll buy it from ya, if you dont want it.Gypsyman said:Merrick,
I have access to a free HT3B/22 new in the box. Do you think 22 would be too tight for a 3rd gen primary? Any ideas on what would be a good secondary for an HPCR? Bare with me as I'm learning as fast as I can.
Richard
Richard
