Ultimate Fueling Module
Service Manual
Just a typical day for the Dog....
Is anyone using a DD Ultimate fueling module that can tell me what to excpect? I am in the process of getting DD3's Will I need to get the boost module too? Or is the Fueling module all I need?
If I am going about this the wrong way can someone steer me in the right direction. I have got a 5" Exhaust and getting DD3's with DD Ultimate fueling module what else do I need to make all of this cone together?
I have their fueling module, It's awsome it also doubles as a boost module. Your are going to need gauges, 4" exhaust, with heavy fueling you need to get rid of heat "EGT's" that's what the larger exhaust does ( helps keep the EGT's lower ). If you have a auto transmission your going to have to beef it up aslo.
You're also going to need a new clutch for your ETH, because your stocker won't last three days before it starts slipping. I'm not sure what to suggest here, but I sure know which one to NOT recommend.
Additionally, an HX-40 wouldn't be a bad idea either because you'll be well beyond the power level that I'm told Pier's turbo works at.
I have the very same setup.
Rob
I just got in from putting a Spicer ceramic clutch, 5" exhaust, boost, pyro, and fuel pressure in the pillar pod. I had all but the exhaust just not put in so what else should I beware of? I want to be going the safe route instead of finding out that I missed something.
Also do you need anything else besides the ultimate fueling module
