Rip at sourceautomotive took on the rebuild, due to a dropped exh valve destroying #5 piston, on tear down discovered alot of needed TLC and replace, new mahle pistons new bearings, new reworked head, new htt 3 piece manifold, since it was apart put in hamilton big stick and springs replaced htt 62/14 with bd super b special. the truck runs great it is smooth quieter than before still breaking in the rings I have drove almost 200 miles back home the turbo I honestly dont feel lag that I thought going bigger with the turbo. I wasn't really hard on the truck on the way home but turbo with the cam comes alive around 1900rpm's. I love the cam, I have noticed the truck really has a solid climb from 1900 to 2500 where I kept it driving it home. untill I put some more break in and miles on I will keep you posted. driving the truck around with the TST and smarty off before it was a dog, just driving it around with everything off and just the cam and sticks it reminded me of driving the truck with the smarty on a mild SW. before when I did oil changes my oil would turn black after driving it in one day around town. after 200 mile trip home the oil looked like it was new. so this does explain why the other pistons needed replaced they were under min standards when the engine was pulled apart. now I know what it is like to have good compression. Rip at source once again thanks for the awesome service and work, thanks the Jkidd at Diesel auto power for the great help with the new turbo. you dont know how depressing it was for almost 2 months to have your DD truck gone but what a great feeling when you get it back and you know the truck was done right and running better than ever before.
2002 HO 6-SPD LB 4X4 QC BD 64/71/14 SB-DD3600 TST PM3/*REVO-BETA*SMARTY MACH 4'S, RINGED AND STUDS,HAMILTON BIG STICK,SPRINGS,HTT 3 PIECE MANIFOLD,AFE/2
" FTE 6" STACK GAUGES, FASS 150, VULCAN 1/2 DRAW-STRAW, 3/8 FUEL LINE, DSS-BOX DT PRO-FAB TRAC BAR, CONV-T STYLE STEERING,BORGENSON BOX AND SHAFT,DUNKS TRACTION BARS, AIR BAGS,17'' KMC BLACK HOSS, 37" TOYO MT'S 6" RCD LONG ARM LIFT. :-laf... THANKS RIP Source Automotive
