2nd Gen Non-Engine/Transmission Upgrade alternator charge cable??
Engine/Transmission (1994 - 1998) Marine Cummins Diesel TDC issue
Engine/Transmission (1998.5 - 2002) 2001?
I came across a 190 denso alternator that I want to install.
I am looking for some ideas on how to upgrade the charge cable to handle the extra power from the alternator. I have some 2/0 marine cable & ends laying around. Is it best to totally replace the cable from the alternator to the fuse panel? Do I keep the current charge cable and run a bigger one to the passenger battery & disconnect the cable from the fuse panel to the drivers sde battery? Do I need an inline fuse in addition to the 140 amp fuse in the fuse box?
Did you leave the factory charge cable to the fuse panel & the cable from the fuse panel to the drivers side battery hooked up as well?
