US Gear Overdrive question
Smarty Jr. She's a smoker now!
I need help choosing a tuner/programmer
Well, its over three years since the last post, does anyone have any other experience w the US Gear product?
I am almost ready to plunk down my $ but since I have a NP205 (which they claim they don't interface to - but I have seen at least two vendors supplying installations). I have been asking them questions. So far they are responsive - but a bit slow.
thanks for your input
Dennis
Dennis,
I wrecked my 2000 truck which had the U. S. Gear unit installed, and now have a 2008 replacement (see signature - It's on my first post, above). I assume that you have the same transfer case I do. I haven't tried to install the U. S. Gear unit on the new truck but I intend to. I will be VERY interested to see if it fits the newer drivetrains.
To install the U. S. Gear unit on the 2000 truck I had to shorten the fuel tank. After crawling under the 2008 truck it doesn't look like I'll have to do that for the new one... Thank heaven.
If you created a signature, we could see what model and year your truck is. That will enable others to help you better. To create a signature, go to the top menu item, "Discussion Forums" and select, "User Control Panel". On the left side at the top, select, "Edit Signature" to create one.
I'll look forward to your results. Thanks.
Loren
