Use soapy water
AFE Air Filters
New Di Pricol pyro gauge reads 200 out of box. Problem or not?
I've had my Grovers in for awhile now, was amazed at how much air they are going through. I have dual aux. air tanks in the tool box, total capacity 22 gallons. I HAD the tanks piggybacked using a length of that yellow extendable hose. I decided to check it today, using some soapy water, could have taken a bubble bath in the tool box with all the leaks :rolleyes: . Come to find out that the yellow hose had worn through were it's connected at the hose barbs on the line. I replaced that line with a piece of the hose that Rickson's supplied, using 1/4"NPT brass compression fittings, now all is well. Not a big deal as all I was losing was air, but be aware of the possible failure if you are running the horns with a compressor and have that yellow line somewhere in the install, it may cost you a dead battery if you don't have your compressor set up to only power up when 'keyed on'. There's a pic. of that yellow line here, if your interested...
https://www.turbodieselregister.com/user_gallery/sizeimage.php?&photoid=1093&width=0
Scott W.
Toolbox
Hey Scott,
Got any room in there for tools?:D :rolleyes:
Oh by the way thanks again for the wiring tip a while back on the install of the Grovers. You gotta love 'em!
Phil
Your not far off Phil... when I first installed the Weathergard box I thought, OMG, what will I ever fill it with, LOL. Yep, still enough room for some tools and a rain jacket. It's amazing how much less air these horns use, when there's not a leak :rolleyes: . The kids at the bus stop were each taking turns again today, when I got home I checked the tanks, hardly budged the gauge needles. Glad that I could help with the wiring, enjoy 'em :cool:
Scott W.
