Using Marine grade grease on the cardan joint?
Gear Ratio Error in 4th, 3rd and 2nd
Truck randomly pukes coolant
I accidentally bought a tube of "Boat Trailer Wheel Bearing Grease" which is made for high salt (ocean water) for backing the trailer in to launch a boat. \
Would this stuff be OK to use on the Cardin joint?
(I didn't have my glasses on when purchasing and could only read the "Wheel Bearing" letter type on the tube...)
Should I take it back - or use it?
That will work fine. I don't know if you live in a place that salts their roads. Marine grade in my opinion is the best. Resists water and corrosive road treatments
Just double checking -
Below are 3 pics of the grease / tube - I bought -
I read where some greases do not mix well with regular lithium types of grease (which lithium is what I have already been using) They say that some greases will "de-activate" each other and either harden up with little lubrication - OR - liquefy with little lubrication.
The new grease is the thicker NLGI 2 - but it says "Carbon Black" (which is what they call the thicker (peanut butter) consistency greases)
I wonder if this stuff will play well with the lithium?
After purchasing - I thought with it being thicker I wouldn't have to grease the cardan every oil change - maybe every other change - but then I did a little research about mixing - I'm just going to exchange it for some lithium.
Dealer told me there is no grease fitting there, because they couldn't find it. I knew where it was, but they wouldn't let me in the shop to point it out, so I greased it myself....once.
I currently have Red Line CV2, and had also looked into Lubriplate Special Auto & Marine. I emailed both companies to verify they were compatible with lithium based grease, and they confirmed that.
Yes doesn't turn on '19, when I engage the front axle you can hear the engagement, I used pulling the little boat up slick launch ramps and there is no dam grease fitting.o_O
