Valve body question
My niece is stranded in CA need help.
gas engine serial number
What is the difference between the 47re and 48re valve bodies? I may be wrong, but I think some of these companies are selling a 47re VB that has been upgraded to guys with 48re trannys. If DCX made significant or meaningful upgrades to the 48re then that is B. S. Input pls! :confused:
There is an extra plate in there. The PRNDL switch is not on the 47RE it just has a P and N switch. The shifter lever is different. I think pre 2000 the solenoid and pressure sensor are different
the plate has a bigger hole in the 2 gear shift,like adding a b&m kit. the plate under the upper v-b near switch valve has been widened to allow the fluid to release quicker for lock up in the t-c. the v-b is of the same diminsions. just has small changes internal,plus the shift lever(rooster comb as called in plant). whats the extra plate? I thought they just changed the plate? I have not built the v-b in 6-7 years, but still can in my sleep. Oo.
