I have a really bad vibration in my truck that starts up if I am running down a bumpy road. I thought it might be the right front hub but it wasn't. I changed it out today and I still have the problem. Somebody mentioned that it could be my front axle disconnect so I checked that out and it is working fine also. The truck will not vibrate in 4wd only 2wd. When I get the vibration, it will go away if I move the transfer case shifter slightly towards 4wd or neutral. I thought this was coming from the front of the truck but now I am not sure. I heard about a problem with a snap ring on these trucks coming loose in the transfer case. Would the symptoms I am having be caused by this? I am planning on a camping trip next weekend pulling my fifth wheel so I am getting desperate to fix it. Any ideas? Thanks
Steve
Steve
