Engine/Transmission (1998.5 - 2002) Video of VP44 install!
2nd Gen Non-Engine/Transmission shocks.....
Engine/Transmission (1994 - 1998) 96 12 valve IAT information
Outstanding ----
There needs to be more of this for many jobs -- i. e. Valve Adjustment... Heater Core on Gen 2's... ...
Great job. . thanks a million.
Something to note, you DO NOT have to remove all the injector lines from every injector. Remove the lines on injectors 1, 2 and 4 you can leave the lines on injectors 3, 5 and 6 . Take 3, 5 and 6 off the VP44 and loosen the hold downs for them then you can gently push them towards the block and the pump will slide back and out. This way you don't have to deal with the rear engine lifting bracket as well.
