Voltage and charging problem
electronic throttle control
P0514 Code
Here’s what I found; had a bad ground on the engine block. So, I fixed that and put the charging system back to factory. The external voltage regulator created a few issues once I started checking a few other things. Poor fuel pressure regulator performance, poor injector performance and I also had pulsing in my electrics and 7.94 volts shorted to the frame. Thank you for your honesty:)
Good to hear, problem solved the proper way.
