Engine/Transmission (1998.5 - 2002) Voltage Spikes...
Engine/Transmission (1998.5 - 2002) HELP, steering box ??
A ground is a ground is a ground, may be other underlying problems. IS voltage spiking or is your instruments losing ground and going erratic? If it is spiking I would look at you alternator. regulating system. If you instruments are erratic look at redoing your ground wires. Hope this helps
I have to say that I don't have any voltage problems as of now. But I was looking at my new FASS to see if I developed any leaks (none so far) and saw the cable had rubbed itself down to the wire.
Thanks for the info.
