Good advice, but I'm still prefilling... That's a whole quart of oil that has to fill that filter before the turbo gets fresh oil. Im not sure the turbo will have a sufficent enough oil film
on the bearings to protect it til the fresh reaches them.
You obviously did not read the thread. It is Dodge AND Cummins that are recommending prefilling the oil filter. Everyone saying not to prefill, like yourself, are the ones claiming to know more than the manufacturers!I have been a diesel engine mechanic for most of my adult life. I have changed oil on engines hundreds of times without filling the filters. Many diesel engines use inverted filters so it is impossible to pre fill... ... ... ... ... . So let me get this straight. We want to be extra good to our mighty Cummins. So we pre fill the oil filter and STRAIN THAT OIL WITH A PAINT FILTER::???????????? This has to be the stupidist thing you could possibly do to a $15,000 engine. DONT FILL THE FILTER!!!! this is a prelude to disaster. .
If you are ever witness to the new engine start up on ANY assembly line the oil filters are NOT pre filled. Do you think Cummins, Cat, John Deere, Detroit do not know how to start new engines?? Ah yes the new owner of a pickup truck MUST know best. .
Changed alot of oil in Cummins engines NHC 220's 250's 335's N14's never filled the filter never had one problem, hard to fill a filter when it mounts on it's side is (horizontle). They all ran no noise rattles etc. Laurie
This thread brings the awesome!
So to all those so strongly against prefilling, please explain why CUMMINS recommends prefilling the oil filter if it is so risky. Is there no benefit what so ever? Are we to believe that the manufacturer of the engine with all their technical knowledge and real world experience on millions of engines somehow got this so very wrong??
Bottom line is do whatever makes you comfortable. If prefilling worries you, then simply don’t do it. For myself, until someone presents solid evidence which clearly shows Cummins is wrong, I will continue to follow their recommendation to prefill the oil filter. YMMV
I hated those PITA horizontal, even the later vertical canister type cartridge filters! So much better when the spin-on was introduced. I never cared much for the huge nasty 'ole Lubrifiner bypass filters either.
Nick
No, no one has yet come right out and claimed Cummins is wrong, but some are telling others to ignore Cummins recommendations and not to prefill. Not sure how that logic works. If prefilling is not wrong and Cummins recommends it, then it should be done, yes? So telling people not to do it has to mean Cummins must be wrong, but you say that is not true. . …. So confusing, lol.I don't think anybody said Cummins is wrong. They are just pointing out that if you get any foreign matter in there, it's after the filter element and will go directly into the engine.
Same problem with prefilling fuel filters which is even more critical. I never prefill fuel filters either.
With the large 4" fuel tank fill opening, just stick your hand and filter down in the tank and fill it, then smell diesel for the rest of the day
Nick
