Engine/Transmission (1998.5 - 2002) water cooled turbo?
Engine/Transmission (1998.5 - 2002) best price on stacks
2nd Gen Non-Engine/Transmission automatic pedal position failure
So I have a turbo that I wanted to use in a small set of twins, h2e. Anyways, it has 4 passages on it, I'm assuming oil, and that it is also watercooled. My next assumption (I hope I'm wrong) is that I shouldn't just run oil to cool it. I mean the water cooling is there for a reason right? Or is it a one or the other, cause that would be awesome.
Anyways, if I do have to run both, where is the best place to tap into the cooling system to get the water I need?
Thanks guys,
Sean
You don't have to run the water cooling. The stock turbos don't have it, they just use the oil. It's a bonus feature of some other turbos.
really thats awesome. I knew that the stock ones didn't have it, I just thought that maybe some turbos required both, but didn't know for sure. Thanks,
Sean
