Its on!!
Well mgoncalves, mlockner and I put on our stage 2 systems today in Laser Bobs garage! (Bob thanks a ton, your the man!! ) (Thanks as well go out to sticks, laser bob, and tajensen, Justin Mars for helping out!! )Install wasnt quite as bad as I thought it might be. Hardest part I thought was trying to find a place to mount the pump and the tank that it comes with. CAUTION!! Be very careful when tapping your air horn, that is some soft aluminum!! Those with the stage 2 kit, that hobbs switch is simple in its use but is hard to tune right on your truck. I think all 3 systems we installed today must of had the thing set to open up at 50psi or something. All 3 trucks can easily make 40 psi and we couldnt turn the pump on. You really have to back out that adjustment a significant amount.
Here are the results my truck saw when we dyno'd after the install party. Keep in mind, I think we all decided these things are going to take some time to understand and tuning is definetely needed to maximize the system
Performance mods on my truck:
Stage 3 injectors (extrude honed)
Blue Chip FMS Premium
Edge EZ (borrowed from sticks, thanks buddy!)
HT Turbo HX 40/35 hybrid Stage 3
Big Exhaust 5" w/ muffler
Stage 2 Snow Performance Methanol System
ATS Stage 2 transmission (TC & Valve Body)
AFE Megacannon
I ran near the same #'s I did 3 weeks ago in Denver (Denver= 520hp----- Fort Collins=518hp) These are #'s without methanol injection but everything else on my truck. Egt's without Water Methanol easily pegged 1650 in a matter of seconds :{
WITH WATER METHANOL
We all ran the el cheapo windshield washer fluid in our systems tonight. Who knows what % methanol it contained. Results are as follows:
555 rwhp (no torque readings, couldnt get the sensor to stay on the truck)
EGT's: 1353 !!!!!!! Thats a 300 degree reduction and 35-37 hp gain on Windshield Washer fluid alone!!!
I need to find me some Methanol and blend 50% Meth, 50% Water!!! Oo. Oo.
First impressions from me are that this system does and will do every bit as much as Matt Snow says it will do and more. I couldnt be more pleased with it, considering we literally slapped these things on as fast as we could and didnt have time to tweak the system much before dynoing, this thing rocks!!! Oo.
