Got a few more uses on the kit now...
It seems that the colder it is outside, the less difference it makes in EGT. Las night I did some hard runs and outside temp was a pretty steady -2 degrees. I couldn't discern a difference in EGT at using the water/meth at that temp. Power was still there, though.
Still haven't tried regular ole washer fluid, I'm interested in the difference that makes against 50/50.
I also changed my switch setup. I have found it works best for me to not use the water/meth in 1st and 2nd gear, and when I am racing powerstrokes I need to be able to hit the switch quick. So, I mounted a different switch and the green LED on a litle bracket on my shifter-much better.
Initially I had some hard starting problems after use of the water/meth, but I think I may not have been drying things out properly after running on the methanol. If I do a hard pull with the methanol on, then drive easy for a mile and shut 'er down, it takes a few seconds to start next time. If I do a short warm up of the EGTs (1250 for a second or two) after being on methanol, she starts just like normal next time. Could be strictly coincidence too, as I haven't truely verified that the water/meth is causing the problem (although the only time my truck has had to crank for more than a second or two is after I used the meth. )
As for the PSD, the owner tells me that his kit doesn't do much, if anything. I think he is just sore 'cause when we raced I beat him
, but he also has his EGT probe post turbo, which would reduce the difference you would see (I would think, anyway). My friend was riding in the PSD and asked the owner to turn off the kit, so he could see/feel the difference, and the owner refused, so who knows. I'm putting a kit on my dad's PSD soon, so I will have concrete results there.
My setup is the same still, in at 8 psi and full at 23 psi. I want to fool with the pump regulator (allen screw) now and see what happens there.
My impression over all is still
, especially for the $$$$$$
Matt
