Water pump blew up
No Power at OSB II port
Edge Insight CTS2?
I can't believe why the term "water pump blew up" was used. Sounds like it was a big bomb that went off and that is absolutely ridiculous!
I inspected mine this past weekend. Did not have vent hole. No play or bearing issues that could be noticed. It’s a 14 with 70k. Guess I need to look further at fan bearing, tensioner, or idler for my squeal. Just curious why the post recall pump only 50$ versus the others??
Just replace it and quit worrying about it. They will reimburse you if you say it failed.
OK, so that was a bit dramatic!
My point is that I spent over $50k for my truck, FCA issues a recall for a part on that truck, they should have the parts to replace the recalled part and it should be done sooner then later. If I can order a pump from Geno's then availability is not an issue.
I will use only cummins supplied pumps or better yet, I won't use gates pumps any more. I had a gates fail in less than 3 months / 5k miles. Don't really care where it was made.
