While driving my 13 Laramie Longhorn in town towing my 5er, the front bearing seized(water pump), and the shaft broke at that bearing.... I don't thing the whole process lasted longer than 1 minute before I felt a stiff power steering and pulled over.... water all over the place, and the pulley sitting in the fan shroud... nothing else damaged....
A call to the local dealer who said... sure we can repair it under warranty.... but we are 3 weeks behind... The towing service would tow the truck (CHRYSLER road service) but wouldn't tow the trailer... an offer of $100 bucks to the mechanic as a tip couldn't sway them to fix it now....
Long story but I called my road service to get both the truck and trailer off the road... Customer pay for a new lifetime water-pump almost $600.00... Now almost 90 days later I'm still waiting for my money back after filling out the forms and submitting them... This all before the recall....
They have a huge issue on their hands here.... there was no warning... just some noise and a minute later, broken belt and no power steering....
Did you submit the tow bill as well??? If not then add it to your claim, you just might get it reimbursed...
Anyone use the ACDelco 252-920 Professional Water Pump. From what I read they may be better quality then the OEM pumps. Have not ordered it yet, from what I can find out it's impressive. About $82.00 + shipping.
I also received the recall notice. Anyone know of a good pump that can be purchased. Don't want to be broke down on the side of the road in sub zero weather.
Would it be less likely the affected pump fail in the winter (sub zero ambient temps)?
I'm traveling to central IL next month.
ALL water pumps have the weep hole.....NOT ALL have the vent hole.I would think the higher the pressure the more chance of failure. So summer time. The problem is no weep hole. No place to bleed off if a leak occurs in the seals. I made a little video on my opinion of the T51 failures if you are interesting.
